TwinTurbo.NET: Nissan 300ZX forum - To make a long story short :) >>>
Subject To make a long story short :) >>>
Posted by ztunerz on April 16, 2011 at 9:55 AM
  This message has been viewed 147 times.
In Reply To Re: It appears you are considering valve shrouding to be posted by S2z on April 15, 2011 at 05:09 PM
Message I went from stock valves to 1 mm over with some portwork to unshroud the valves and reshape the runners especially on the exhaust side and i gained flow thru the entire lift range. I bolted these heads on to 88 mm block and see a power increase across the board.
I used no math, instead i got some good advice from an experience engine builder and i tested everything on the same flow bench.
Maybe old school but it worked.
Harry
Formerly yellowzxtt
